Same tool 2 operations do not want the tool to go home in between operations.
rak70463
Message 1 of 10
rak70463
I have a turning tool CNMG to face and finish turn. It faces retracts to home the comes in to do finish pass. How do I get it to face and the just do the finish turning. My turning tools dont have the do not go home check box.
Replies (9)
Message 2 of 10
seth.madore
Which post processor are you using?
Seth Madore
Message 3 of 10
rak70463
I haven't posted it out it is doing it in simulation.  But I am using the Doosan fanuc post.
Message 4 of 10
akash.kamoolkar
@rak70463 is the issue here that you don't want the tool to retract to X = clearance radius between operations?
Akash Kamoolkar
Software Development Manager
Message 5 of 10
seth.madore
This is a bug in the post.  There are a couple of changes that need to be made to fix it:
var machineState = {
tailstockIsActive : false, // <<< Change to false // Engage tailstock
if (getProperty("useTailStock") != "false") {
// <<< Change currentSection.useTailStock to currentSection.tailstock in the following command
if (!retracted && ((currentSection.tailstock || forceTailStock) != machineState.tailstockIsActive)) {
goHome();
retracted = true;
engageTailStock(true);
Seth Madore
Message 6 of 10
seth.madore
I've edited the generic Doosan Turn/Mill post processor to produce the code you are expecting. That said, I'm not a Post Processor expert (by any stretch of the imagination), so please do test very carefully. Currently, the machine is set to "LYNX" (which has no Y axis, but a tailstock and part catcher)
Seth Madore
Message 7 of 10
rak70463
In simulation it goes home the does finish pass I want the tool to face then do the finish pass then go home.
Message 8 of 10
seth.madore
@rak70463 did you see the post processor I attached in my prior post? I'm wondering if you had a chance to try it out and was that able to work around the issue?
Seth Madore
Message 9 of 10
HughesTooling
Do these setting help?
Mark Hughes
Owner, Hughes Tooling
Message 10 of 10
rak70463
Thank you yes it fixed it!
