Router just raises and trips Z limit switch
eisenmanguitars
Message 1 of 16
eisenmanguitars
When I open this process up in UGS, and start the operation, my router raises up and hits the limit switch immediately.  I have no error notifications in my setup or toolpath.
I'm assuming it's a setting in my manufacture tab.  FYI I erased an old project off this file, incase anything weird is left over.  Any idea what I did wrong? Here's what UGS says:
>>> G90
>>> T1
>>> S5000M3
>>> G54
ok
ok
[Error] An error was detected while sending 'S5000M3': (ALARM:1) Hard limit has been triggered. Machine position is likely lost due to sudden halt. Re-homing is highly recommended. Streaming has been paused.
[MSG:Reset to continue]
Replies (15)
Message 2 of 16
GeorgeRoberts
Good morning
A few questions regarding this:
  • Does your machine move at all? It should home in Z prior to the codes you shared in the message
  • Do you have a programmable spindle and can it go to 5000rpm? The line showing your error below is indicating the spindle line is causing the issue
  • Does the machine move in XY? IT should move in XY prior to trying to perform a Z move (after the spindle has turned on)
  • Have you set the work offset correctly on your machine? Your code is G54, so ensure you have enough XY travel from the position you set this work offset to
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Message 3 of 16
eisenmanguitars
Hi George, thanks for your time.  The machine moves as it typically does, prior to pressing play on the program.  I home the machine, then I bring it to zero, then I raise Z a few steps to give some clearance the way I always do.
The spindle is just a router with a manual wheel on it, so it is not programmable.  I turn it on manually.  I haven't run into this being an issue before, I've never adjusted spindle speeds for projects, only feed rate.
The machine jogs in XY and Z just fine prior to starting the program.  Once the program has started, it moves up in the Z axis as its very first move, then limits.
I believe I have enough XY travel.  The piece is well in from the X and Y limits of my machine.  It's the area of the bed I typically machine in.
Thank you!
Message 4 of 16
eisenmanguitars
I have tried several things, but the same problem keeps occurring.  Here is the lates info from UGS:
>>> G0X1.095Y-0.1297
>>> Z0.6
>>> G1Z0.2F40
>>> Z0.0894F13.33
>>> Z-0.0375
>>> X1.0949Y-0.13Z-0.0403F40
>>> X1.0948Y-0.131Z-0.0429
[Error] An error was detected while sending 'G0X1.095Y-0.1297': (ALARM:1) Hard limit has been triggered. Machine position is likely lost due to sudden halt. Re-homing is highly recommended. Streaming has been paused.
>>> X1.0945Y-0.1324Z-0.0453
Message 5 of 16
seth.madore
Could you share your Fusion file here, and what post processor are you using? You mention UGS, but that's your g-code sender, right? What post are you using to create the g-code from Fusion?
Have you previously run Fusion toolpaths thru your machine?
Seth Madore
Message 6 of 16
eisenmanguitars
Hey Seth, thanks for your attention to this!  I've attached the file.  I right click on my toolpath, then select post process.  At that point I'm using GRBL, I hope I'm answering your question.  I have run many toolpaths on this machine through fusion, in this way (seemingly).
Message 7 of 16
seth.madore
and could you share your latest g-code file here as well, that will help me to determine what's going on
Seth Madore
Message 8 of 16
seth.madore
I suspect it's the G28 line at the beginning. If you change your "Safe Retracts" to "Retract Height", does it work then?
Note: you will have to manually insure that the tool is above the stock before hitting the start button
Seth Madore
Message 9 of 16
eisenmanguitars
Sure!  Here it is.
Message 10 of 16
eisenmanguitars
That did in fact get it to start cutting.  What gives?  I've never had to change that before?  Also, I noticed on your screen shot that you are selecting output tool number, where I was not.  What is that?
Message 11 of 16
seth.madore
That (output tool number) was just a default setting in the post.
As to why you now have to select "Retract Heights", I suspect you were using a generic GRBL post and a recent update changed the behavior.
Do yourself a favor; safe a copy of the post to a local folder and use THAT post from now on.
Seth Madore
Message 12 of 16
eisenmanguitars
Thanks a lot for your help Seth! a little added bonus... After every toolpath operation (for a long time now) my router would always move up, limit out and throw a z alarm.  I always had to reset and home before making the next cut.  It doesn't do that anymore!
Message 13 of 16
seth.madore
Awesome, good to hear!
Seth Madore
Message 14 of 16
programming2C78B
G28 is a common issue with the default GRBL post and the fact that A LOT of hobby cnc builders are not putting in a Z limit switch, so they turn the machine on then jog to find G54.
Please click "Accept Solution" if what I wrote solved your issue!
Message 15 of 16
simon.robinsonPUN8X
Observer
Observer
Is this post still live as I would like to ask a similar question relating to Z height?
Message 16 of 16
eisenmanguitars
Not active, closing now. Good luck with your issue!
