Rotary operations Gcode output is wrong need help
Hello everyone, I used rotary command on this part, it using circular passes and I set angular limit 0 to 359 degress. When i simulate operation everything is fine, part is rotating between 0-359 degrees but, when I take gcode output Rotary axis (A axis) going up to above 500 degrees. I tried several different post processors and I took same results. How can I solve this?
