rigid tapping
rigid tapping
emre_sahin9PU3F
rigid tapping
emre_sahin9PU3F
I want to add the rigid tapping feature but I don't know how to do it. Also, how to remove the / sign in /M43 line? There is no G53 in the post option. I ask for your help.
seth.madore
What exactly are you looking in your syntax, what's there and what needs to be added/removed?
For your second question regarding the "/" at the M43, you'll want to edit line 1387, setting it to false:
      setOptionalSkip(false);
Seth Madore
emre_sahin9PU3F
Hi @seth.madore ,
I need your superior experience and knowledge. 😊
1- I want to activate the rigid tapping feature. Rigid tapping activation code is M129, rigid tapping cancellation code is M128. M129 should be opened in the line above the line starting with G84.
2. I can process the post content with the C axis, but it does not have the Y axis feature. The only post structure that fits my machine's operating system is in this Fusion library. Can you add the Y axis feature?
3- Sometimes I need to change the machine reference point to G53 Z... G53X... instead of G28 W0 G28 U0. Among the post removal options, there is only the Z home option. No G53.
