Just a quick one, thanks to NYC CNC, I came across this handy tip to use previous operations "model" in next operation for rest rough....see link below.
https://www.youtube.com/watch?v=9toDzfXcGo8
Following on from this, I have a question about the file name and how is it used.
So, is it necessary to save each and every "model" from different operations as a different file name or can I continue to use the same file name and override previous versions with a new model for use with a completely different program/operation? So, does Fusion continue to look for the same file if I were to go back into my original program to make changes at a later date when I have overridden that "model" with one from another operation or is the original "model" stored somewhere on the cloud and can only be overridden if I change/update the "from file" name?
I know it may sound a little confusing, but just want to clear this up before I make the most of this nice feature.
PS - can we get a folder shortcut icon added to locate the file instead of having to copy & paste the (full) file name?
