Rest Machining for cutting op
So I've worked around this enough that I'm annoyed. I'm running a cnc plasma and I'm running into a part where I need different operations with different lead in's and different kerf offsets. However if I select the face contour for the second op there is no rest machining (like in milling or setup) or a way to ignore op1 cuts. Normally i just select the contours individualy .
