I am trying to do Rest Machining and cannot get the second setup to generate a valid tool path. I have followed the setps in the Autodesk Knowledge Network - Continue rest machining between setups (Sep 20, 2021) but must be doing something wrong. I do three setups, each with a different tool. In the attached file, I do the first tool path with an engraving bit and engrave tool path. I then clean out the cavity with a 1/8 inch cutter and then want to do rest machining with a 1/16 cutter to get into the corners that the 1/8 inch tool could not reach. The tool path in the Setup1 (4) 1/16 Bit does not generate and gives the warnings "No passes to link" and "Empty toolpath". I have selected the component "maple board:1" for all three setups and have rest machining selected in Setup1 (4) 1/16 Bit and its associated tool path "[T11] 2DPocket (8).
What am I doing wrong or does rest machining not work for what I am trying to do?
Thank you
Doug
