Request: Add Order Top-Bottom in Flow.
jacobXNNNF
jacobXNNNF
Why is there no control of up or down milling in Flow? Ramp has the ability to set the order to Bottom-Up. Flow becomes very limiting as you pretty much are stuck with whatever direction it chooses. Like in the photos below you can see how I chose 4 different surfaces. There's nothing I can do to tell Flow to go down in Z so I'm stuck with an operation that is very likely to cause tear-out since I'm milling wood. Can we get more fine tuning of Flow so it has a broader use case?
a.laasW8M6T
If you are using legacy Flow then you can select a preferred entry point to force the tool path to start at a different position:
This is in the linking tab
This doesn't work in the new Flow(Preview) toolpath though which is a major frustration as otherwise its a major upgrade on the old Flow.
jacobXNNNF
Unfortunately I have already tried moving the starting position. It doesn't affect much really since the starting point is already at the top. Since I have two small adjacent surfaces to the large surface, it prioritizes the small ones and basically the starting point becomes inconsequential no matter where you put it.
seth.madore
We're aware of this limitation in Flow and are working on improving the usability of this toolpath. Stay tuned for future updates where we might see a "Top/Bottom" (or Up/Down) option 😉
Seth Madore
bgarrington
still no update on this issue ?
seth.madore
We've improved this internally, you should see this in a future update 🙂
Seth Madore
bgarrington
ok great thanks for the update 🙂
