Ranura Curva
Ranura Curva
ricardogarcia23
Ranura Curva
ricardogarcia23
Hola,
tengo que abrir una ranura curva, con Pencil he conseguido que la haga bastante bien, pero el desbaste me da problemas... como puedo hacerlo?
adjunto modelo
Un saludo.
engineguy
@ricardogarcia23
I think that the easiest way is probably to do the Slot is to use a 2D Contour with a Slotting Cutter, in the image below I have used both "Multiple Depths" and "Roughing Passes" so the steps down and in for best results but you can do it any way you like, see image below and attached file, open the file and run the Simulation to see how it is doing the Slot 🙂 Hope it is of some help 🙂
