"The output folder for the selected NC program could not be created."
kanleeD9CMZ
Observer Observer
kanleeD9CMZ
Observer
Observer
I'm relatively new to cam machining. I've done around 100+ programs so far on Fusion 360.
I've just finished my most involved part with 8 set-ups and 48 operations.
I went to post process the operations and set up under my first set-up and the error message above appeared.
First time I've seen this.
seth.madore
Were you posting code to a USB drive that was disconnected? Can you share a screenshot of your posting dialog?
Seth Madore
kanleeD9CMZ
Observer
Observer
I get the following fault see attachment. I even tried to open up previous files that I had produced g-codes and machined the part before. I get the same fault on the
old file. I'm setting up the jobs as always, same machine, etc...
thanks,
Kan
kanleeD9CMZ
Observer
Observer
I got the problem solved. The output folder was not specified on the post process window.
We had our computers worked on and settings got changed....
Kan
