"Failed to add sharp corners, since it gouges the boundary"
echatzief
echatzief
I am creating a 2d contour operation, while selecting 3 silhouette geometry selections (being the external loop of each body). I need to contour all 3 bodies at once, while using a 12 mm flat end mill. The distance between a body from another happens to be equal to the tool's diameter in my case, but I am getting a wrong toolpath creation (that does not contour all of my bodies) when sharp corners option is selected.
Changing it into selecting "roll corners", leads to an incorrect toolpath as well.
Reducing the tool's diameter or leaving stock is something I want to prevent from happening.
Thank you!
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
