Quick question about probing.
boyd.sofield
boyd.sofield
The last time I tried this inside a Fusion program. Something went horribly wrong, and my probe shot through my part so badly that it bent and I actually disassembled it to see if there was damage. That was about 4 months ago.
If someone wouldn't mind correcting me if I am incorrect and I have one other question: Mach 3 and I have a post that was made for probing by someone online - with thanks.
Ok so I plan to perform a second op on a part that needs to be exact for the second op (holes and a contour). This is flipping a part, and facing it on G54 approximate WCS because I am facing a larger part than the model. The Z will be precise though measured on the bottom of my part.
Then, I am calling for a probe WCS the X and Y. I have setup for a tool-change, insert my probe. Run the probing routine. I guess it will go to the current zero on X and Y, at the clearance height. Drop down, and probe the two faces I have selected. I don't have "override WCS checked" because underneath it has "WCS to be updated.... 1" written underneath.
Now, is this operation supposed to now update my G54 WCS in Mach 3 to the new coordinates the probe would have found? All automatic yes? Then will the machine ask for the next tool, and the next op begins just like that. All correct? I used to put in a manual stop, probe, continue the program.
The other question is, what does "Override Driving WCS" checkbox do?
Hope my probe doesn't crash again...... really I do.
Richard.stubley
Hi @boyd.sofield,
Sorry to hear you have had issues in the past.
In theory, Yes, exactly the process you describe is what should happen. However its all down to how its been implemented in the post and sub programs.
Can you attach the NC code that your post will produce this might help in me doing a quick sanity check.
Also for Override Driving WCS here is a video I made on it.
https://www.youtube.com/watch?v=X4qCU0X1pWM&t=222s
Richard Stubley
Product Manager - Fusion Mechanical Design
boyd.sofield
Hi. Oh we have to have these crashes once or twice - its how we learn lol.
Hey I just tried to post this program and it errored with something I have not seen before I have absolutely no idea how to fix this?
Information: Configuration: Mach3Mill+probing(mlm Solutions)
Information: Vendor: Artsoft
Information: Posting intermediate data to 'E:\probe\1001.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Friday, June 18, 2021 10:47:07 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5765.0
Configuration path: C:/Users/boyds/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/mach3mill+probe_sz7740adjusted.cps
Security level: 1000
Include paths: C:/Users/boyds/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Monday, February 22, 2021 8:24:58 AM
Output path: E:\probe\1001.nc
Checksum of intermediate NC data: 4a92809a5ba8d0c25f98be06535b6ec7
Checksum of configuration: eb3e899a7f32b8b75f64d2ed55e30026
Vendor url: http://www.machsupport.com
Legal: Copyright (C) 2012-2019 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.10356
Error: ReferenceError: setMach3Variables is not defined
Error at line: 1288
Error in operation: 'Probe WCS2'
Stack dump:
onCyclePoint(-16,-16,31)@C:/Users/boyds/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/mach3mill+probe_sz7740adjusted.cps:1287
Failed while processing onCycle() for record 685.
Error: Failed to execute configuration.
Stop time: Friday, June 18, 2021 10:47:07 PM
Post processing failed.
