I have two 3D printers & normally use external slicers (mostly Simplify3D, via menu function "Make - 3D print".
Looking at the ongoing developments in Fusion 360's Manufacture environment, I was getting interested in using this for slicing?
As both my printers are unsupported as yet, I took the generic set to see how it would work out for me.... An object that would take approx 11h in my normal slicer was stated to take approx. 150 hours using the generic processor.
So, in order to compare settings & maybe be able to tell where an issue might be, I also downloaded a processor for an Ultimaker 2 (as my smallest printer is pretty close to that model & design). I loaded a CAD model that would run for about 3 1/2h as per Simplify3D's estimate - in the Ultimaker 2's settings, it calculated 6h 23min. Close to twice the actual time...?
Interestingly, there were warnings here:
- Support speed reduced to max extruder speed
- Sparse infill speed ... (same)
- Solid infill speed ... (same)
- Internal perimeter speed ... (same)
So, that might point somewhere... But when going through the settings for the Ultimaker 2 & its filament settings, I can't find an entry for max extruder speed? Am I overlooking something or it the max extruder speed a derived value? If so, where do I need to look in order to evaluate?
As said above - at the moment, there aren't any processors for my printers, but I noticed an application was released to help people develop their own processors as required: I'm considering to use that solution. But before I'd embark on such a trial & error journey, especially considering I'd might be risking my large delta printer's integrity, I'd really like to understand what I'm doing... 😎
