proxxon FF500 4 AXIS
tommaso_beltrani
tommaso_beltrani
Hi to all users of the forum, I have a Proxxon FF500/BL CNC milling machine whose management program is nccad9 profi with Kosy language. I recently bought the 4 axis ut400/cnc. Unfortunately I can't create a CNC program because after programming in fusion it gives me an error. it only works on one face when I rotate the tool and therefore Z axis says that Kosy does not support this operation. how can I solve it? thanks in advance
AdamKunzo
You need to modify post processor.
I offer post processor modification as a service, send me a message if you would like to get a help and I will sort out this for you.
seth.madore
If you're not afraid of tinkering a bit and want to learn some editing in the process, this article gives you a walkthrough of what is needed:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-make-a-3-ax...
Seth Madore
tommaso_beltrani
Hi Adam can you explain to me how your service works?
AdamKunzo
I just sent you message.
