Programming a climb cut but only get conventional cut in 2D profile
vadermann
Observer Observer
vadermann
Observer
Observer
I'm trying to do a finish cut on 304L stainless steel. .75 deep by .02 sidewall 1.0 Radius followed by 2.5 inch straight cut. No matter the direction selected to cut from sideways compensation on the passes tab the result is always conventional cut, opposite the direction for which the arrows are pointing.Screenshot 2023-03-21 124348.jpg
seth.madore
That's odd..
Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
DarthBane55
You have 2 arrows, which means you selected those 2 as separate profiles.  You should select them as just 1 continuous profile.
