I'm wondering if it possible in Fusion to cut a dimension that is different to the model.
Today I'm machining (in the lathe) a part that has a tight tolerance on a diameter of 95.20-95.25 mm. The model was supplied to me by the customer so changing it isn't an option. They have modelled the dimension at 95.25 mm but ideally I'd like to program at bottom limit (95.20 mm). I have used the wear offset limit in the control to bring the dimension where I want it to be but this is having a knock on effect on other part dimensions.
Is there a feature within fusion that would allow me to do this?
