Problems with 5 axis parallel toolpath
Hi all
I'm having problems with this parallel toolpath and was wondering if anybody had a solution. I'm currently using parallel with multi axis enabled driving it from a curve, the toolpath itself works, however when running the toolpath on my Hermle C20U, as the tool reaches the summit of the part, rather than rotate round and follow a curve it spins at the top leaving a blemish in the part.
As you can see from image 1 that is the toolpath that fusion has generated, image 2 is a closeup view of the toolpath and you can see that the tool axis vectors are doing an unwanted motion which is resulting in the tool spinning at the top of the part. Has anyone had this problem before, or better yet got a solution?
Thanks in advance
Image 1
Image 2
