Problems programming tool path for an elliptical pocket
Mortronitron
Mortronitron
Hello!  I made a pocket using the ellipse tool and then an extrude/cut.  When I try to program a 2d pocket, it selects the ellipse, but just shows the path as a straight line across the top.  When I run the simulation, I get nothing.  I've tried several different selection options and none seem to work.  What am I missing?
Thanks!
seth.madore
It looks to me that you've not setup your part correctly in Fusion Manufacture. When creating a Setup, it defaults to "Model Orientation", which adopts the alignment of what you have in Design. Now, parts aren't always oriented correctly or the same, so we have options to "Define Z and X axis" to account for that.
Seth Madore
Mortronitron
Hello, thanks for the reply.  This is my setup selections:17F62C4E-C06D-412D-8B5B-A4475B89947B.jpeg
seth.madore
You need to select a surface that's aligned with the Z axis and then an edge (or sketch) that is aligned with the X axis.
Seth Madore
Mortronitron
Ah dang, I didn't notice I hadn't select the Z axis, stupid mistake, thank you!
