problems milling a sphere
calexpavel
calexpavel
I'm trying to program a phere roughing and i don't know why but i only get a cilinder in the middle.
https://a360.co/2HE4s3d
Can anyone help?
Thanks!
calexpavel
it works if the mesh has triangles, but not with quads as i can see. Any tip?
johnswetz1982
Your linked file no longer has a sphere in it. You'll get more responses if you attache the file (file>export) rather than attaching a link that changes when you save or change the file.Sphere.jpg
HughesTooling
Most CAM systems convert Breps to a point cloud or mesh at some point. I guess Fusion uses a mesh so and imported mesh can be used directly by the CAM system without conversion but it has to be a triangulated mesh. There is an option in properties to triangulate imported meshes, this is only for the insert mesh from the insert menu.
Mark
Mark Hughes
Owner, Hughes Tooling
