Problem with thread can
beug4133
beug4133
get a warning that toolpath is not supported for the given tool will likey have  to select another tool? I need to tap 4 holes .4in deep with 10-32 tap,  o.03125 pitch.  Anny ides of what I am doing wrong? Thanks
HughesTooling
My guess is you're trying to use the Thread op, you should use Drill and select tap as the cycle type. The thread op is for thread milling.
Mark
Mark Hughes
Owner, Hughes Tooling
beug4133
You are spot on Thanks so much!
