ok its very difficult to explain but I will try
it does not matter what the am file is the result is the same
ok download the generic PP from the web site
set up a generic a axis machine from your library
point that to the above PP
run a simple 3 axis file and the machine details appear in he post before the tool list
ok that works
but now I have a file that uses the a axis
so as I have done before alter the statement in onopen from false to true
now if I use the machine config in the setup file it fails on onopen with no info why
but if I remove the machine config from the setup and just select the PP from the personal list it works
now the machine description will not show up in the gcode output , but if I remove the onopen changes they show up again
