Problem with post process Planet CNC Lathe
Hi, I am new to Fusion 360 and CNC in general. As a result of seeing   many CNC videos online and observing their capability, I decided to  build a CNC Mill router which I was  very happy with, I then decided  to build a CNC Lathe.  Perhaps, I was over ambitious and did not realise the complexity of the job. It has  been a very steep learning curve from mechanical to the software and I have unfortunately hit a dead end.
The problem is not a post process for CNC USB lathe specific like CNC USB Mill so I used Generic Faunc Turning but the origin xz i set on Fusion 360 is origin centre of X but when I ,convert to Generic Faunc Turning and transfer to Planet CNC software the origin is at the back of X part so I don't know  what the problem is but I set the origin of the machine centre  x and z. I have some photos to explain this better.
manni8TPAS
Observer
Observer
HI,
I am having the same issue, any help will be appreciated.
I am using fusion 360 to generate gcodes. for my CNC USB Lathe. MK1 planet cnc controller
I tried all post processors for turning.
keep on getting same error,
" error in GCode! Radius to end of arc is different from radius to start (92)
please check attached file which was made in  file from fusion 360.
Thank you in advance
Manni
