Message 1 of 11
09:19 PM
Hi, I'm trying to machine the teeth (not sure what its called), I have tried almost all of the operation but most of them dont generate toolpaths/ toolphats that only machine part of the teeth. The teeth is 1.02mm wide, I'm using a 1mm flat end mill for this. I would like my end mill to run up an Z-Y plane along the contour of the teeth I understand fusion does not allow us to machine a 1mm pocket with an 1mm end mill, this is why the teeth are 1.02mm wide, accurary is not very important here. Anyone has any idea? Thanks!
