Problem with Linking parameters
I have tried to link the two dimension values in the Fusion 360(Design Workspace), but I could not. After careful observation, what I have found is, one dimension is assigned  negative value and other has positive value and the negative value is allotted to that dimension, because it is representing the Offset of the line inside part not outside. Please someone help me, I have been trying to solve this problem. Thank you in advance.
Marco.Takx
Hi @Anonymous,
After reading your question I still don’t know what the issue is.
Can you please share your file?
Without seeing it, it is hard to help you with your problem.
Within Fusion 360, choose File > Export and save it on your desktop.
After that upload it to this topic so that one of us can take a look at it.
Please try also explaining better what you are after.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
