Problem with generated G codes or Fuision 360 setup
I’ve a problem with generated G codes from Fuision. I’m using self build machine “open builds type” 1000mm x 1000mm
Now doesn’t matter if I post code as a GRBL or do machine setup in Fuision the effect is exactly the same.
I can load G code to open builds controller, the tool paths are visible with in perimeter of the work bed, machine will run “check the size” I can probe the bit but it won’t run the program.
When I disable limiters program starts but Z axis goes up and won’t stop (I’ve only 80mm travel on Z)
