Probing WCS not working on Extended Offsets
vpace91423
vpace91423
Just ran into a situation with our Haas VF5SS. Normally we probe our WCS with normal offsets G54-G59. We did a part the other day and did G54.1P19. The probe went through the function but did not update the work offset. If I switch back to G54-G59, it is fine. Does it only work on the standard offsets?
rengfx
What post were you using?
HAAS nomenclature for additional WCS however is "G154.XX" so I suspect there is an issue potentially in specifying
Can you post the Gcode or a picture? The key string here will be the S value on the G65 callout
