Preview Features - Tool Library issue
spmalone
spmalone
Community Visitor
Community Visitor
When adding a new tool some of the setting are not showing.
obrienm
Hi @spmalone ,
Thanks for reporting this.
Another user has had the same problem here : https://forums.autodesk.com/t5/fusion-360-manufacture/cam-tool-library-broken-after-update/m-p/94424... .
I would suggest turning off the tool library preview via the preferences menu while we investigate the issue.
Mark O'Brien
Senior Software Engineer
nathaniel.avery86R8N
Hi @spmalone,
To help try and determine the cause of this problem, could you follow this guide to get Fusion's graphics diagnostics for your machine and either post it as a reply or private message it to me? If you can provide me with more information about the computer you're using that would be really useful as well.
Many thanks,
Nathaniel
Nathaniel Avery
Software Engineer, Fusion 360
spmalone
Community Visitor
Community Visitor
Good morning Nathaniel,
[GPU Information]
GPU Device: AMD Radeon(TM) R5 340X
GPU RAM: 2048 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 22.19.162.4
GPU Driver Date: 05/03/2017
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Display
[Limit effects to optimize performance]
Off
Intel Core i7-6700 @ 3.40 GHz 3.41 GHz
Ram 16.0 GM
64-bit
Windows 10 Enterprise
Version 1909
OS Build 18363.752
