Preventing multiple post processing of the same fusion operation
m_lamarca
m_lamarca
Is there a way to prevent the long list of fusion NC Programs, when someone decides to post an operation again and again and again, instead of reposting it off of the NC Programs side of the tree?
I can only ask the guys so many times, before I start beating them with dead blow hammers….
HughesTooling
You can disable creation of the NC programs if you uncheck Create In Browser.
You can still force the creation of an NC program from the right click menu if you uncheck the option on the post dialog
Mark Hughes
Owner, Hughes Tooling
m_lamarca
I don’t seem to have that option.
HughesTooling
I sort of remember it being in preferences but can't find it.
Not sure if it's enabled if you have the setting below checked.
Mark Hughes
HughesTooling
OK not the setting above.
Did you right click an operation or setup then select Post or did you try posting an NC Program to get that dialog?
Posting from a setup should give you the same dialog I have.
Mark Hughes
m_lamarca
Got it!
thank you.
