PP Only Tool Table Infos (Subprog)
U.Uhl
U.Uhl
Does anyone have an idea or PP where I can only get the tool information or just the tool table.
I would like to use the whole thing to check on the machine whether the tool is available or for new sorting.
It would also be possible to implement this in the machine PP so that it is always output as a SUB program.
boopathi.sivakumar
we have a couple of post which would output the tool sheet in CSV or HTML you could use output!
Boopathi Sivakumar
Senior Technology Consultant
U.Uhl
Thanks for the tip, I found something that I could remodel for myself.
Now the only idea would be how can I automatically integrate this into the "main post" so that it is always output as a sub program.
matty.fuller
Entirely possible... if you know JavaScript and consult the post processor documentation, a little reverse engineering will speed you on your way.
U.Uhl
I took a look or tried it. I think the whole thing is a bit over my head to implement the code so that it is output as a subprogram.
In the Siemens840d post it's a little different.
