Potential Collision Detected NGC alarms
arie.fournier
Message 1 of 8
arie.fournier
Hello, I am wondering whether me post of my mill is going haywire. When I created a Swarf toolpath I will get no alarms on Fusions side, and when I run the graphics on my UMC-500 I have no alarms either. When I start the program the tool will do 2 spirals before halting with an error message " 9108 Potential Collision Detected". I've already turned off setting 408 (exclude tool from safe zone) to no differing results.
What I don't under stand is the fact that I've ran a rotation tool path right before this, and the tool cuts .200 closer to the jaws. When the Swarf path alarms out the tool much be .750-1.0 away from the exit of the rotation tool path.
Replies (7)
Message 2 of 8
rengfx
Message 3 of 8
arie.fournier
Yes MRZP has been set.
378: -10.0000 (X)
379: -9.0157 (Y)
380: -19.9212 (Z)
When the alarm is triggered the tool is at these positions.
X: -17.0836
Y: -7.9649
Z: -13.0021
B: 89.905
C: -67.866
Message 4 of 8
FrodoLoggins
You wouldn't happen to have safe run on the NGC active? I get a lot of false positives with it enabled on on my mills.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Message 5 of 8
arie.fournier
I don't believe so. How would I check?
What I've been able to do in the mean time though is raise my "Z" 1 inch, and the program ran perfectly fine. What bothers me though is the this inconsistency between graphics/simulation and the machine itself. It pains me to get an hour into a program for it to alarm on the last couple tool paths.
Message 6 of 8
FrodoLoggins
I'm assuming it's not turned on because if it was on you'd have a big green "Safe Run" text inside the memory/MDI panel:
With the memory/MDI panel active (you'd know it's active if the text box has a white background as shown in screenshot, not grey background) pressing the F3 key enables/disables Safe Run.
Message 7 of 8
arie.fournier
Ah I see.
Nope safe run is not active.
Something tells me the safe zones are not correctly set up. Something about a completely rounded number (-10.0000) doesn't sit right. Have you had this alarm on your HAAS?
Message 8 of 8
FrodoLoggins
I haven't touched safe zones at all on my machines so I don't think I can help much. Sorry.
