Can you share the file the post is failing on? Export as an f3d and attach. One thing you can try, go into your preferences and change the nc editor to notepad and post again, notepad starts faster than the editor supplied with Fusion and catches the error file. Or try having your editor running before you post. My guess is you're trying to use a feature not supported by your post processor, which post processor are you using.
Mark
Mark Hughes
Owner, Hughes Tooling
