Posting OD turning outputs taper
johnmathisen
Message 1 of 9
johnmathisen
I seem to have an odd issue with posting a finish outside profile for my lathe. For some reason it will turn the front radius then about 0.5 inches along the diameter it will start tapering out by 0.0013 inches. I created the model so I know it doesn't have a taper on the OD of the model. I can easily just delete the extra X values and it works but it would be nice for it to post correctly.
G95 G90 G18
G54
M8
G97 S958 M3
G0 X-1.395
Z0.05
G96 D1000 S350 M3
G0 Z0.0205
X-1.2297
G1 X-1.2579 Z-0.0001 F0.01
G2 X-1.3356 Z-0.0355 I0.0092 K-0.0491 F0.002
G1 X-1.3386 Z-0.0468
Z-0.1101
Z-0.5416
X-1.3391 Z-0.5811
X-1.3395 Z-0.6207
X-1.3397 Z-0.6602
X-1.3399 Z-0.6998
Z-0.7393
Z-1.171
X-1.3486
X-1.3839 Z-1.1533 F0.01
G0 X-1.395
Z0.05
G97 S958 M3
Replies (8)
Message 2 of 9
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 3 of 9
johnmathisen
I didn't really want to post my design online but I think I have discovered what is causing it. I have some text embossed on the outside edge and when I suppress the text it posts with correct X values. I was going to make a generic version of my part and as such I didn't add the engraving. When posting a regular cylinder, the X values are were correct hence my discovery. I would think when you have don't allow grooving turned on it should ignore and indents or grooves no?
Message 4 of 9
johnmathisen
I also tried groove suppression by selecting the floor of each letter but it still posts a taper.
Message 5 of 9
seth.madore
Yes, it should.
You can always email me the file: seth DOT madore AT autodesk DOT com
Please link this thread in your email so I understand the context 🙂
Seth Madore
Message 6 of 9
johnmathisen
I emailed you the file. I found 1 solution is to copy the body and then delete the faces of the emboss. I then used that body for the OD turning setup which fixed the taper output for now.
Message 7 of 9
seth.madore
This looks like an issue with the Spun Profile, I'll send this along to the proper teams to investigate
Seth Madore
Message 8 of 9
johnmathisen
Ah ok I see turning that off fixes it but then you cant use groove suppression if you need to. Pretty sure it also defaults with spun profile checked because I don't remember going to that and clicking on the check box.
Message 9 of 9
seth.madore
Yes, Spun Profile is on by default
Seth Madore
