Seems when I use the "post to nc program" option I get different output code than using the normal post dialog. Using A slightly modified Haas NGC post. The main error is on the G187 line. With the normal post dialog I get:
G187 P3 E.0005 *(I have the E value output same as "tolerance" on passes tab)
With post to NC program I get:
G187 P3 *missing the "E" value.
Also noticing that some of the "post properties" selections are defaulting to different values than what are set in the post file or not showing at all on the list..
Any ideas?
Post file is attached for reference.
Please click "Accept Solution" if I helped with your question or issue.
