Post sequence numbers only at the start of each toolpath
jackwcallen
jackwcallen
I need to change my post to only post sequence number at the start of each toolpath.
For instance:
N1 (DRILL2)
M09
M01
T12 M06
T6
I saw a post a while ago that had only the sequence numbers at each tool change, but can't find it for the life of me.
Although if we are able to get it with the comment at the start of each toolpath would be better.
Many thanks for any thoughts.
Steinwerks
Some of the generic posts have the option of "sequenceNumberOnlyOnToolChange" such as the Haas, and I've modified ours to only output on Operations so I would be glad to help with this. Which post processor are you using now? If it is anything but a generic, please attach it here.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
jackwcallen
That would be fantastic.
Post attached, it is a very slightly modified version of the generic fanuc post. Just an end of program position move.
Many thanks.
Steinwerks
Try this post. I also added the sequenceNumberOnlyOnToolChange, but that is overridden by the sequenceNumberOnlyOnOperation option, it won't do both. It's set up so the default is to show the sequence numbers on operation.
As usual, two notes always mentioned:
1) Do NOT put this in the default directory! You probably already know this, but for anyone else finding this for the first time, it will be overwritten during the next update if it is in the default location. Better to put it in Cloud or Personal posts areas.
2) Test with caution!
Neal Stein
Find me on:
jackwcallen
That is fantastic. I couldn't be more grateful.
Thanks so much for helping me with that.
Thanks for the tip as well about the default post directory, I did unfortunately learn about that the hard way a few months ago.
Again many thanks.
atrepair
Can sequenceNumberOnlyOnOperation  be added to the Brother Speedio Post? If not can you explain how to customize it so I can do this myself?
