Post properties reset after restart
scullum9DXSB
scullum9DXSB
I have an issue with my post properties resetting after every fusion restart. I see there are three dots to the side of each check box. Is that supposed to set your default? Nothing changes upon clicking those dots. I'm looking for a setting to keep defaults even after restart. We have many fusion seats, and they all do the same thing.
seth.madore
It "should" be keeping the settings you chose from the last time you used that post processor. It's odd that it's not working as intended.
Do you always want particular settings, across all your seats? One sure-fire method would be to modify those parameters in the post processor, which is a very simple task. What's the post processor(s)?
Seth Madore
scullum9DXSB
So, it looks like I'm able to change it inside the post and it remains once you restart fusion. However, when I exported it and someone else imports the settings reset again inside the post. Seems strange. It looks like we will have to change it in everyone's seats after each import. After that they can restart any time and the settings will stay the same.
seth.madore
Are all the users in the same Team Hub and using a Cloud stored post processor, or is it a locally stored post?
Seth Madore
scullum9DXSB
Currently they are in different hubs. There is talk about join the same team however not everyone is on board. Currently on our own hubs. So, we use have them on our individual clouds.
CGBenner
@scullum9DXSB Do you still need more help with this?  @seth.madore any additional ideas?
Chris Benner
