Post processor problem with AXYZ machine
robotyachts
Observer Observer
robotyachts
Observer
Observer
Hi all, I have been having an issue when machining an arc the post processor is adding small 5mm radius along the arc length in random places.  I can see it in the code but would appreciate if someone could tell me how to remove it from the post processor. I'm pretty sure  that the r5's in the below code are what is causing the problem.
Any help appreciated,
James
N10 G90G21
N20(2D CONTOUR2)
N20 M6T8
N30 S18000M3
N40 M7
N50 G0X-0.542Y165.577
N60 Z115.
N70 G0Z86.
N80 G1Z56.F1069.
N90 Y165.57Z55.879F3206.
N100 X-0.543Y165.548Z55.761
N110 X-0.545Y165.512Z55.645
N120 X-0.548Y165.463Z55.535
N130 X-0.552Y165.4Z55.432
N140 X-0.556Y165.326Z55.337
N150 X-0.561Y165.241Z55.251
N160 X-0.566Y165.146Z55.177
N170 X-0.572Y165.043Z55.115
N180 X-0.578Y164.933Z55.065
N190 X-0.585Y164.818Z55.029
N200 X-0.592Y164.699Z55.007
N210 X-0.599Y164.579Z55.
N220 X-0.656Y163.58
N230 G17G3X0.286Y162.525R1.
N240 G1X9.726Y161.985F4000.
N250 X9.732Y161.984
N260 X19.198Y161.431
N270 X19.205
N280 X28.706Y160.863
N290 X28.713
N300 X38.259Y160.278
N310 X38.268Y160.277
N320 X47.868Y159.672
N330 G2X47.879Y159.671R5.
N340 G1X57.544Y159.042
N350 G2X57.555R5.
N360 G1X67.294Y158.387
N370 G2X67.307Y158.386R5.
N380 G1X77.131Y157.701
N390 G2X77.143Y157.7R5.
N400 G1X87.06Y156.984
N410 G2X87.073Y156.983R5.
N420 G1X97.041Y156.237
N430 G2X97.054Y156.236R5.
N440 G1X107.024Y155.465
N450 G2X107.036Y155.464R5.
N460 G1X116.993Y154.671
N470 G2X117.004Y154.67R5.
N480 G1X126.933Y153.858
N490 X126.942
engineguy
@robotyachts
With respect no one can tell just from the code whether the R5 moves should or should not be there.
Have you tried using the "Relative" (IJK) type arcs option instead of the "Radius" (R) type arcs and see if the random arcs still appear, some CNC controls don`t work well with the Radius arcs 🙂
Also, it is much, much better if you can upload a problem Fusion file by going to :-
File > Export > Select f3d format > Save to a location on your computer > Then attach the file to your reply, a copy of the PP being used would also be helpful in diagnosing your issue 🙂
Stay Safe
Regards
Rob
will_1
Hi @robotyachts ,
If you want to linearize arcs change allowedCircularPlanes to zero and you won't get anymore arc moves, linear moves
allowedCircularPlanes = 0;
From your description I am not really sure what the issue is you are running into. If you can supply more information I might be able to help more.
Will
