I am using the standard Torchmate 3 Post Processor with fusion for my plasma table. When I load the code into the torchmate I get a few errors, if I remove the lines of code that are causing the error it works fine. So I need some help learning how to edit the post. I have attached three posted files for a simple 1/4" thick 6"x6" rectangle.
The first is generated by RhinoCam and what I have been using for years. The second if the code generated by Fusion that gives the errors, the third is the fusion file with the deleted code that cuts the part out just fine.
I did have to disable the useZ property to get rid of fusion trying to control the Z height.
Can anyone direct me in the right way to edit the post to output the desired code with the problem lines eliminated. I also would like to know how to add a line of code so the machine returns to 0,0 when its done cutting the part.
I have put in three pictures of the errors that come up do you can see just what was going on. Note that it shows two errors for line 6, I deleted line 6 which then reset all the lines, and line 7, also causing an error, was renamed line 6.
