Post processor G43 question
andrew.irwin
andrew.irwin
Hi has any one done a post for mach3 that dosn't use G43 or H(tool number) offsets.
i am removeing them at the moment but would prefer not to as doing manualy is to pron to errors.
Andrew
AchimN
Try the one attached please 😉
Achim.N
Principal Technology Consultant
andrew.irwin
thank you for that.
What you did is better then what I did, I erased instead of commenting out as you did. But now, I would suggest adding a property and a if statement such that one can easily switch on or off the insertion of a G43 code, this wthout having to edit the post processor again.
While I'm at it, I see an object named machineConfiguration in this same file, but I can't find anything on this object, maybe you can help with that as well?
Yves
AchimN
This is normally only needed for multi axis machining and not really useful for 3 axis.
You can have a look into the manual if you are interested here:
https://camforum.autodesk.com/index.php?topic=6138.msg24305#msg24305
Achim.N
ANDERSONRODANDCHOPPER
