Hi everyone,
does anyone have a takamaz lathe post processor for fanuc 18i-T?
Hi everyone,
Hello @GianlucaCimaomo
depending on the machine, several solutions are available.
If it's a 2 axis lathe, using the generic Fanuc turning post is a good starting point.
https://cam.autodesk.com/posts/download.php?name=fanuc%20turning&type=post
If it's a turn mill machine with C and Y axis capabilities, then a specifc post need to be developped.
Turn mill machine are using specific M and G codes, that are Machine Builder dependant.
We don't have such post in the library actually.
You can eventually try to modify an existing post to match your machine code.
Or you can contact one of our service provider to have one developped for your needs.
Given our partners can provide more localized support, we would encourage you to investigate the partners in your area, which can be done through our Services Marketplace.
https://servicesmarketplace.autodesk.com/providers/service-speciality/post-processing
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
