Post Processor for a MORI SEIKI NL3000Y/1250 CNC Turning Center
jeph00
jeph00
Any available or does anyone have a suggestion for me? Fusion 360 data base has:  dmg mori nlx mill-turn.cps
Or will that post processor work on our machine?
Thanks in advance for your time.
johnswetz1982
Is it a Mori or a DMG? What kind of controller is it, because DMG makes several controllers available for the machine?
jeph00
Its an 05 Mori Sieki. The CNC controller is MORI MSX 850 III
billcainautodesk
Hello jeffmwald
Most Likely the NLX post will work with the older NL as long as the control is from the same manufacture. The NLX is a newer version of the machine. They program pretty much the same as a NL Program will run on a NLX machine. The NLX may have a few newer codes but they should be easy to remove or change in the post.
Bill Cain
Bill Cain
Sr. Technical Consultant
jeph00
Okay, I'll start working with that post then. Thanks!
