Post Processor editing.....not as easy as I thought.
Message 1 of 16
It seems as though I was highly unrealistic in my assumptions as to editing a  pre-existing post. Looking back now I don't know what I "thought" it was going to look like; I only know it's significantly removed from my level of focus and patience. This, to some, may sound just plain lazy, and I get that. As in a small business often the laws of physics don't seem to apply. More often than not, s#i+ flows up hill. Were it merely a matter of want that would impede my attempt; I feel like I could muster the fortitude to carry through. That just isn't the case for many; myself included.
 Would it be possible to provide sample code; both edited and as posted, to someone/service and just pay them to edit the post in question? It seems as though I am utilizing Fusion-360 more and more often, simply for the HSM function. As a Mazak shop (based on the brunt of simplistic part geometry we encounter) programming a part in Fusion-360 is NEVER (and I do mean NEVER) even close to the speed with which we can be producing parts by programming at the control in Mazatrol. Often, the Fusion-360 program will "win out" with the amortization of the programming/setup time figured into the part quantity but more often than not; it won't. This, I realize, is simply due to the type of work that we are generally tasked.
 With that said, a significant contributing factor to this being; the a$$loads of editing required to produce a program that will run (at all, let alone safely, or in the manner we'd prefer) in some of our older Mitsubishi "Meldas" powered Mazak "Mazatrol M32's and M-Plus." No, I can't afford to replace the older controls with the new SMOOTH controlled Mazatrol machines just so we could completely eliminate offline/CAM programming all together........I'm hoping I can afford to have a few posts edited though.
 Can anyone recommend a particular company, service provider, or individual that does this sort of thing "on the side" that is reputable and reasonably priced? Any help would be greatly appreciated.
                                   Kind regards,
                                      Mike Ward.
Replies (15)
Message 2 of 16
Steinwerks
Hi Mike,
Yes, you can always get a post quote from a reseller. I have heard good things regarding Silverhawk although have not used their services myself. A full list of resellers can be found here: http://cam.autodesk.com/resellers/
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 16
friesendrywall
It would be nice to see what you are really after in a customized post, but judging from the other thread, some things I notice is that you really have to watch f360 and its cam smoothing to prevent lots of segments in some operations.
Whoever you get really needs to understand your control, preferably having used one.
You could also post an example and output of what you aren't liking about the current post and some could help you here.
Its all javascript, a decent programmer should be able to do it, with the caveat that he understands what a machine crash is/costs.
Message 4 of 16
Thank you, I'll reach out to one of them for more information.
                             Kind regards,
                                   Mike Ward.
Message 5 of 16
Very good point; I know what you mean regarding the short line segments and ENORMOUS file sizes generated by most CAM systems utilizing controlled engagement angles. I do not see myself as being terribly bright but, it would seem like there would be a more logical way for CAM systems to create simple arcs (basic 2.5D tool paths) by implementing G02/G03 functions whenever possible; often many lines of code to generate a single arc segment. When roughing, I've tried using gross deviation parameters in effort to cut down on excessive code, with less than expected results. This is not to say this phenomenon is unique to Fusion-360; it seems to be an industry "method" at this point.
 Is it simply a matter of computing power, a matter of the software having to be so "universal" in it's approach to be viable in the market place, or is there something I'm TOTALLY missing here? I apologize for my naivety on the topic; just to curious to care.
I'll reply later with a sample of code, both edited and "as posted." Any opinions would be appreciated.
                                                    Kind regards,
                                                      Mike Ward
Message 6 of 16
This is a sample of edited code.
O1010
N1 G90 G94 G17 G00
N2 G20
N4 T1
N3 G91 G30 Z0 Y0 X0 M19
N6 M06
N7 T2
N10 G90 G54
N12 X2.875 Y0.6 S900 M03
N13 G43 Z1.1 H01
N15 Z0.1 M08
N16 G98 G81 X2.875 Y0.6 Z-0.03 R0.1 F5.7
N17 X1.3438 Y-0.15
N18 X2.0112 Y-0.87
N19 X-1.4183 Y0.3042
N20 X-1.5424 Y0.1445
N21 X-1.7349 Y0.1989
N22 X-1.9273 Y0.2534
N23 X-2.1198 Y0.3078
N24 X-2.3122 Y0.3623
N25 X-3. Y-0.5
N26 G80 M09
N29 G91 G30 Z0 Y0 X0 M19
N32 M01
N33 M06
N34 T4
N37 G90 G54
N39 X-3. Y-0.5 S500 M03
N40 G43 Z1.1 H02
N42 Z0.1 M08
N43 G81 X-3. Y-0.5 Z-0.7439 R0.1 F3.
N44 G80 M09
N47 G91 G30 Z0 Y0 X0 M19
N50 M01
N51 M06
N52 T6
N55 G90 G54
N57 X2.875 Y0.6 S935 M03
N58 G43 Z1.1 H04
N60 Z0.1 M08
N61 G81 X2.875 Y0.6 Z-0.58 R0.1 F5.8
N62 G80 M09
N65 G91 G30 Z0 Y0 X0 M19
N68 M01
N69 M06
N70 T8
N73 G90 G54
N75 X1.3438 Y-0.15 S1320 M03
N76 G43 Z1.1 H06
N78 Z0.1 M08
N79 G81 X1.3438 Y-0.15 Z-0.53 R0.1 F6.4
N80 X2.0112 Y-0.87
N81 G80 M09
N84 G91 G30 Z0 Y0 X0 M19
N87 M01
N88 M06
N89 T3
N92 G90 G54
N94 X-2.3122 Y0.3623 S2400 M03
N95 G43 Z1.1 H08
N97 Z0.1 M08
N98 G73 X-2.3122 Y0.3623 Z-0.45 R0.1 Q0.125 F7.
N99 X-2.1198 Y0.3078
N100 X-1.9273 Y0.2534
N101 X-1.7349 Y0.1989
N102 X-1.5424 Y0.1445
N103 X-1.35 Y0.09
N104 X-1.4183 Y0.3042
N105 G80 M09
N108 G91 G30 Z0 Y0 X0 M19
N111 M01
N112 M06
N113 T5
N116 G90 G54
N118 X-3. Y-0.55 S2400 M03
N119 G43 Z1.05 H03
N120 Z0.08 M08
N121 G01 Z0.05 F50.
N122 G18 G02 X-2.95 Z0. I0.05
N123 G17
N124 G01 G41 X-2.925 Y-0.8 D33
N125 G03 X-2.625 Y-0.5 J0.3
N126 X-3.375 Z-0.0197 I-0.375 F25.
N127 X-2.625 Z-0.0394 I0.375
N128 X-3.375 Z-0.0591 I-0.375
N129 X-2.625 Z-0.0787 I0.375
N130 X-3.375 Z-0.0984 I-0.375
N131 X-2.625 Z-0.1181 I0.375
N132 X-3.375 Z-0.1378 I-0.375
N133 X-2.625 Z-0.1575 I0.375
N134 X-3.375 Z-0.1772 I-0.375
N135 X-2.625 Z-0.1969 I0.375
N136 X-3.375 Z-0.2165 I-0.375
N137 X-2.625 Z-0.2362 I0.375
N138 X-3.375 Z-0.2559 I-0.375
N139 X-2.625 Z-0.2756 I0.375
N140 X-3.375 Z-0.2953 I-0.375
N141 X-2.625 Z-0.315 I0.375
N142 X-3.375 Z-0.3346 I-0.375
N143 X-2.625 Z-0.3543 I0.375
N144 X-3.375 Z-0.374 I-0.375
N145 X-2.625 Z-0.3937 I0.375
N146 X-3.0864 Y-0.1351 Z-0.405 I-0.375
N147 X-2.9136 Y-0.8649 I0.0864 J-0.3649
N148 X-3.0864 Y-0.1351 I-0.0864 J0.3649
N149 X-3.3092 Y-0.4961 I0.0691 J-0.2919 F50.
N151 G01 G40 X-3.0602 Y-0.4629
N152 X-3.0589 Y-0.4683 Z-0.4047
N153 X-3.0576 Y-0.4737 Z-0.4037
N154 X-3.0564 Y-0.4789 Z-0.4022
N155 X-3.0552 Y-0.484 Z-0.4
N156 X-3.054 Y-0.4888 Z-0.3973
N157 X-3.053 Y-0.4932 Z-0.3941
N158 X-3.052 Y-0.4973 Z-0.3904
N159 X-3.0512 Y-0.5009 Z-0.3862
N160 X-3.0504 Y-0.5041 Z-0.3816
N161 X-3.0498 Y-0.5067 Z-0.3767
N162 X-3.0493 Y-0.5088 Z-0.3715
N163 X-3.0489 Y-0.5103 Z-0.3661
N164 X-3.0487 Y-0.5112 Z-0.3606
N165 Y-0.5115 Z-0.355
N166 G00 Z1.05 M09
N168 G91 G30 Z0 Y0 X0 M19
N171 M01
N172 M06
N173 T7
N176 G90 G54
N178 X2.935 Y0.413 S2750 M03
N179 G43 Z1.1 H05
N180 Z0.1375 M03
N181 G19 G03 Y0.4492 Z0.1 J0.0375 F35.
N182 G01 Y0.7875 Z0.0882
N183 G17 G03 X2.815 Z0.0816 I-0.06
N184 G01 Y0.4125 Z0.0685
N185 G03 X2.935 Z0.0619 I0.06
N186 G01 Y0.7875 Z0.0488
N187 G03 X2.815 Z0.0422 I-0.06
N188 G01 Y0.4125 Z0.0292
N189 G03 X2.935 Z0.0226 I0.06
N190 G01 Y0.7875 Z0.0095
N191 G03 X2.815 Z0.0029 I-0.06
N192 G01 Y0.4125 Z-0.0102
N193 G03 X2.935 Z-0.0168 I0.06
N194 G01 Y0.7875 Z-0.0299
N195 G03 X2.815 Z-0.0365 I-0.06
N196 G01 Y0.4125 Z-0.0496
N197 G03 X2.935 Z-0.0561 I0.06
N198 G01 Y0.7875 Z-0.0692
N199 G03 X2.815 Z-0.0758 I-0.06
N200 G01 Y0.4125 Z-0.0889
N201 G03 X2.935 Z-0.0955 I0.06
N202 G01 Y0.7875 Z-0.1086
N203 G03 X2.815 Z-0.1152 I-0.06
N204 G01 Y0.4125 Z-0.1283
N205 G03 X2.935 Z-0.1349 I0.06
N206 G01 Y0.7875 Z-0.1479
N207 G03 X2.815 Z-0.1545 I-0.06
N208 G01 Y0.4125 Z-0.1676
N209 G03 X2.935 Z-0.1742 I0.06
N210 G01 Y0.7875 Z-0.1873
N211 G03 X2.815 Z-0.1939 I-0.06
N212 G01 Y0.4125 Z-0.207
N213 G03 X2.935 Z-0.2136 I0.06
N214 G01 Y0.7875 Z-0.2267
N215 G03 X2.815 Z-0.2332 I-0.06
N216 G01 Y0.4125 Z-0.2463
N217 G03 X2.935 Z-0.2529 I0.06
N218 G01 Y0.7875 Z-0.266
N219 G03 X2.815 Z-0.2726 I-0.06
N220 G01 Y0.4125 Z-0.2857
N221 G03 X2.935 Z-0.2923 I0.06
N222 G01 Y0.7875 Z-0.3054
N223 G03 X2.815 Z-0.3119 I-0.06
N224 G01 Y0.4125 Z-0.325
N225 G03 X2.935 Z-0.3316 I0.06
N226 G01 Y0.7875 Z-0.3447
N227 G03 X2.815 Z-0.3513 I-0.06
N228 G01 Y0.4125 Z-0.3644
N229 G03 X2.935 Z-0.371 I0.06
N230 G01 Y0.7875 Z-0.3841
N231 G03 X2.815 Z-0.3907 I-0.06
N232 G01 Y0.4125 Z-0.4038
N233 G03 X2.8253 Y0.3789 Z-0.405 I0.06
N234 X2.935 Y0.4125 I0.0497 J0.0336 F34.
N235 G01 Y0.7875
N236 G03 X2.815 I-0.06
N237 G01 Y0.4125
N238 G03 X2.8253 Y0.3789 I0.06
N239 X2.8317 Y0.3717 Z-0.4037 I0.0311 J0.021 F50.
N240 X2.8391 Y0.3666 Z-0.4 I0.0247 J0.0282
N241 X2.8464 Y0.3638 Z-0.394 I0.0172 J0.0333
N242 X2.8522 Y0.3626 Z-0.3863 I0.01 J0.0361
N243 X2.8559 Y0.3624 Z-0.3772 I0.0042 J0.0373
N244 G01 X2.8572 Z-0.3675
N245 G00 Z1.1
N247 S2000 M03
N249 X2.9073 Y0.7186
N251 Z0.1
N252 G01 Z0.0394 F50.
N253 Z-0.3675 F30.
N254 Y0.7188 Z-0.372
N255 X2.9074 Y0.7197 Z-0.3765
N256 X2.9075 Y0.721 Z-0.3808
N257 X2.9076 Y0.7229 Z-0.3849
N258 X2.9078 Y0.7252 Z-0.3888
N259 X2.908 Y0.728 Z-0.3924
N260 X2.9083 Y0.7312 Z-0.3956
N261 X2.9086 Y0.7347 Z-0.3984
N262 X2.9089 Y0.7386 Z-0.4007
N263 X2.9092 Y0.7427 Z-0.4026
N264 X2.9095 Y0.747 Z-0.4039
N265 X2.9098 Y0.7515 Z-0.4047
N266 X2.9102 Y0.756 Z-0.405
N268 G41 X3.1187 Y0.7775 D35 F50.
N269 G03 X2.8943 Y1.0393 I-0.243 J0.0187
N270 X2.6225 Y0.7875 I-0.0193 J-0.2518 F12.
N271 G01 Y0.4125
N272 G03 X3.1275 I0.2525
N273 G01 Y0.7875
N274 G03 X2.6225 I-0.2525
N275 G01 Y0.4125
N276 G03 X3.1275 I0.2525
N277 G01 Y0.7875
N278 G03 X2.8943 Y1.0393 I-0.2525
N279 X2.6326 Y0.8149 I-0.0187 J-0.243 F50.
N281 G01 G40 X2.8354 Y0.7617
N282 X2.8351 Y0.7572 Z-0.4047
N283 X2.8347 Y0.7528 Z-0.4039
N284 X2.8344 Y0.7484 Z-0.4026
N285 X2.8341 Y0.7443 Z-0.4007
N286 X2.8338 Y0.7405 Z-0.3984
N287 X2.8335 Y0.7369 Z-0.3956
N288 X2.8333 Y0.7337 Z-0.3924
N289 X2.833 Y0.7309 Z-0.3888
N290 X2.8329 Y0.7286 Z-0.3849
N291 X2.8327 Y0.7267 Z-0.3808
N292 X2.8326 Y0.7254 Z-0.3765
N293 Y0.7246 Z-0.372
N294 X2.8325 Y0.7243 Z-0.3675
N295 G00 Z1.1 M09
N297 G91 G30 Z0 Y0 X0 M19
N300 M01
This is the "as posted" code.
O1011
(T1  D=0.5 CR=0. TAPER=90DEG - ZMIN=-0.03 - SPOT DRILL)
(T2  D=0.7187 CR=0. TAPER=135DEG - ZMIN=-0.7439 - DRILL)
(T3  D=0.5 CR=0. - ZMIN=-0.405 - FLAT END MILL)
(T4  D=0.4844 CR=0. TAPER=118DEG - ZMIN=-0.58 - DRILL)
(T5  D=0.375 CR=0. - ZMIN=-0.405 - FLAT END MILL)
(T6  D=0.3437 CR=0. TAPER=118DEG - ZMIN=-0.53 - DRILL)
(T7  D=0.25 CR=0. - ZMIN=-0.405 - FLAT END MILL)
(T8  D=0.1875 CR=0. TAPER=118DEG - ZMIN=-0.45 - DRILL)
(T9  D=0.1875 CR=0. - ZMIN=-0.405 - FLAT END MILL)
(T10  D=0.25 CR=0. TAPER=45DEG - ZMIN=-0.05 - CHAMFER MILL)
(T12  D=0.75 CR=0.015 - ZMIN=-0.1563 - BULLNOSE END MILL)
N1 G90 G94 G17
N2 G20
N3 G28 G91 Z0.
N4 G90
(DRILL2)
N5 M09
N6 T1 M06
N7 T2
N8 S625 M03
N9 G54
N10 M08
N12 G00 X2.875 Y0.6
N13 G43 Z1.1 H01
N15 G00 Z0.1
N16 G98 G81 X2.875 Y0.6 Z-0.03 R0.1 F3.4
N17 X1.3438 Y-0.15
N18 X2.0112 Y-0.87
N25 X-3. Y-0.5
N26 G80
N27 Z1.1
N29 G28 G91 Z0.
N30 G90
(DRILL3)
N31 M09
N32 M01
N33 T2 M06
N34 T4
N35 S435 M03
N36 G54
N37 M08
N39 G00 X-3. Y-0.5
N40 G43 Z1.1 H02
N42 G00 Z0.1
N43 G81 X-3. Y-0.5 Z-0.7439 R0.1 F3.3
N44 G80
N45 Z1.1
N47 G28 G91 Z0.
N48 G90
(DRILL4)
N49 M09
N50 M01
N51 T4 M06
N52 T6
N53 S650 M03
N54 G54
N55 M08
N57 G00 X2.875 Y0.6
N58 G43 Z1.1 H04
N60 G00 Z0.1
N61 G81 X2.875 Y0.6 Z-0.58 R0.1 F3.1
N62 G80
N63 Z1.1
N65 G28 G91 Z0.
N66 G90
(DRILL5)
N67 M09
N68 M01
N69 T6 M06
N70 T8
N71 S910 M03
N72 G54
N73 M08
N75 G00 X1.3438 Y-0.15
N76 G43 Z1.1 H06
N78 G00 Z0.1
N79 G81 X1.3438 Y-0.15 Z-0.53 R0.1 F3.5
N80 X2.0112 Y-0.87
N81 G80
N82 Z1.1
N84 G28 G91 Z0.
N85 G90
(DRILL6)
N86 M09
N87 M01
N88 T8 M06
N89 T3
N90 S1670 M03
N91 G54
N92 M08
N94 G00 X-2.3122 Y0.3623
N95 G43 Z1.1 H08
N97 G00 Z0.1
N98 G73 X-2.3122 Y0.3623 Z-0.45 R0.1 Q0.125 F3.8
N103 X-1.35 Y0.09
N105 G80
N106 Z1.1
N108 G28 G91 Z0.
N109 G90
(BORE1)
N110 M09
N111 M01
N112 T3 M06
N113 T5
N114 S2960 M03
N115 G54
N116 M08
N118 G00 X-3. Y-0.55
N119 G43 Z1.05 H03
N120 G00 Z0.08
N121 G01 Z0.05 F50.
N123 G17
N124 G01 G41 X-2.925 Y-0.8 D03
N126 X-3.375 Z-0.0197 I-0.375 F23.7
N166 G00 Z1.05
N168 G28 G91 Z0.
N169 G90
(2D POCKET2)
N170 M09
N171 M01
N172 T5 M06
N173 T7
N174 S3150 M03
N175 G54
N176 M08
N178 G00 X2.815 Y0.5397
N179 G43 Z1.1 H05
N180 G00 Z0.1375
N181 G19 G02 Y0.5032 Z0.1 J-0.0375 F35.
N182 G01 Y0.4125 Z0.0976
N183 G17 G03 X2.935 Z0.0927 I0.06
N184 G01 Y0.7875 Z0.0829
N185 G03 X2.815 Z0.0779 I-0.06
N186 G01 Y0.4125 Z0.0681
N187 G03 X2.935 Z0.0632 I0.06
N188 G01 Y0.7875 Z0.0534
N189 G03 X2.815 Z0.0484 I-0.06
N190 G01 Y0.4125 Z0.0386
N191 G03 X2.935 Z0.0337 I0.06
N192 G01 Y0.7875 Z0.0238
N193 G03 X2.815 Z0.0189 I-0.06
N194 G01 Y0.4125 Z0.0091
N195 G03 X2.935 Z0.0042 I0.06
N196 G01 Y0.7875 Z-0.0057
N197 G03 X2.815 Z-0.0106 I-0.06
N198 G01 Y0.4125 Z-0.0204
N199 G03 X2.935 Z-0.0254 I0.06
N200 G01 Y0.7875 Z-0.0352
N201 G03 X2.815 Z-0.0401 I-0.06
N202 G01 Y0.4125 Z-0.0499
N203 G03 X2.935 Z-0.0549 I0.06
N204 G01 Y0.7875 Z-0.0647
N205 G03 X2.815 Z-0.0696 I-0.06
N206 G01 Y0.4125 Z-0.0794
N207 G03 X2.935 Z-0.0844 I0.06
N208 G01 Y0.7875 Z-0.0942
N209 G03 X2.815 Z-0.0991 I-0.06
N210 G01 Y0.4125 Z-0.109
N211 G03 X2.935 Z-0.1139 I0.06
N212 G01 Y0.7875 Z-0.1237
N213 G03 X2.815 Z-0.1286 I-0.06
N214 G01 Y0.4125 Z-0.1385
N215 G03 X2.935 Z-0.1434 I0.06
N216 G01 Y0.7875 Z-0.1532
N217 G03 X2.815 Z-0.1582 I-0.06
N218 G01 Y0.4125 Z-0.168
N219 G03 X2.935 Z-0.1729 I0.06
N220 G01 Y0.7875 Z-0.1827
N221 G03 X2.815 Z-0.1877 I-0.06
N222 G01 Y0.4125 Z-0.1975
N223 G03 X2.935 Z-0.2024 I0.06
N224 G01 Y0.7875 Z-0.2122
N225 G03 X2.815 Z-0.2172 I-0.06
N226 G01 Y0.4125 Z-0.227
N227 G03 X2.935 Z-0.2319 I0.06
N228 G01 Y0.7875 Z-0.2418
N229 G03 X2.815 Z-0.2467 I-0.06
N230 G01 Y0.4125 Z-0.2565
N231 G03 X2.935 Z-0.2614 I0.06
N232 G01 Y0.7875 Z-0.2713
N233 G03 X2.815 Z-0.2762 I-0.06
N234 G01 Y0.4125 Z-0.286
N235 G03 X2.935 Z-0.291 I0.06
N236 G01 Y0.7875 Z-0.3008
N237 G03 X2.815 Z-0.3057 I-0.06
N238 G01 Y0.4125 Z-0.3155
N239 G03 X2.935 Z-0.3205 I0.06
N240 G01 Y0.7875 Z-0.3303
N241 G03 X2.815 Z-0.3352 I-0.06
N242 G01 Y0.4125 Z-0.345
N243 G03 X2.935 Z-0.35 I0.06
N244 G01 Y0.7875 Z-0.3598
N245 G03 X2.815 Z-0.3647 I-0.06
N246 G01 Y0.4125 Z-0.3746
N247 G03 X2.935 Z-0.3795 I0.06
N248 G01 Y0.7875 Z-0.3893
N249 G03 X2.815 Z-0.3942 I-0.06
N250 G01 Y0.4125 Z-0.4041
N251 G03 X2.8253 Y0.3789 Z-0.405 I0.06
N252 X2.935 Y0.4125 I0.0497 J0.0336 F34.3
N253 G01 Y0.7875
N254 G03 X2.815 I-0.06
N255 G01 Y0.4125
N256 G03 X2.8253 Y0.3789 I0.06
N257 X2.8317 Y0.3717 Z-0.4037 I0.0311 J0.021 F50.
N258 X2.8391 Y0.3666 Z-0.4 I0.0247 J0.0282
N259 X2.8464 Y0.3638 Z-0.394 I0.0172 J0.0333
N260 X2.8522 Y0.3626 Z-0.3863 I0.01 J0.0361
N261 X2.8559 Y0.3624 Z-0.3772 I0.0042 J0.0373
N262 G01 X2.8572 Z-0.3675
N263 G00 Z1.1
(2D CONTOUR2)
N265 S2100 M03
N266 M08
N267 G00 X2.9073 Y0.7186
N268 Z1.1
N269 Z0.1
N270 G01 Z0.0394 F50.
N271 Z-0.3675 F30.
N272 Y0.7188 Z-0.372
N273 X2.9074 Y0.7197 Z-0.3765
N274 X2.9075 Y0.721 Z-0.3808
N275 X2.9076 Y0.7229 Z-0.3849
N276 X2.9078 Y0.7252 Z-0.3888
N277 X2.908 Y0.728 Z-0.3924
N278 X2.9083 Y0.7312 Z-0.3956
N279 X2.9086 Y0.7347 Z-0.3984
N280 X2.9089 Y0.7386 Z-0.4007
N281 X2.9092 Y0.7427 Z-0.4026
N282 X2.9095 Y0.747 Z-0.4039
N283 X2.9098 Y0.7515 Z-0.4047
N284 X2.9102 Y0.756 Z-0.405
N286 G41 X3.1187 Y0.7775 D05 F50.
N287 G03 X2.8943 Y1.0393 I-0.243 J0.0187
N288 X2.6225 Y0.7875 I-0.0193 J-0.2518 F12.5
N289 G01 Y0.4125
N290 G03 X3.1275 I0.2525
N291 G01 Y0.7875
N292 G03 X2.6225 I-0.2525
N293 G01 Y0.4125
N294 G03 X3.1275 I0.2525
N295 G01 Y0.7875
N296 G03 X2.8943 Y1.0393 I-0.2525
N297 X2.6326 Y0.8149 I-0.0187 J-0.243 F50.
N299 G01 G40 X2.8354 Y0.7617
N300 X2.8351 Y0.7572 Z-0.4047
N301 X2.8347 Y0.7528 Z-0.4039
N302 X2.8344 Y0.7484 Z-0.4026
N303 X2.8341 Y0.7443 Z-0.4007
N304 X2.8338 Y0.7405 Z-0.3984
N305 X2.8335 Y0.7369 Z-0.3956
N306 X2.8333 Y0.7337 Z-0.3924
N307 X2.833 Y0.7309 Z-0.3888
N308 X2.8329 Y0.7286 Z-0.3849
N309 X2.8327 Y0.7267 Z-0.3808
N310 X2.8326 Y0.7254 Z-0.3765
N311 Y0.7246 Z-0.372
N312 X2.8325 Y0.7243 Z-0.3675
N313 G00 Z1.1
N315 G28 G91 Z0.
N316 G90
(2D POCKET3)
N317 M09
N318 M01
N319 T7 M06
N320 T9
N321 S1910 M03
N322 G54
N323 M08
N325 G00 X1.7909 Y-0.6505
N326 G43 Z1.1 H07
N327 G00 Z0.125
N328 G01 X1.79 Y-0.6497 Z0.1174 F35.
N329 X1.7874 Y-0.6475 Z0.1105
N330 X1.7834 Y-0.6439 Z0.105
N331 X1.7783 Y-0.6394 Z0.1014
N332 X1.7726 Y-0.6344 Z0.1
Message 7 of 16
friesendrywall
Did you hand edit it?
Can you roughly condense the changes?
For starters, you can set writeTools to NO in the post options.
Message 8 of 16
Yes, I hand edited it; I'll reply shortly with a brief "play by play" of the edit and reasoning behind it. On another note; I took a little time last night and started playing with the edit of my current post (Generic Mitsubishi Meldas) in Notepad++ last night with some success! The "G28" at the head of the program that needed to be a "G30" was successfully altered. When I attempted to add the required "X0" "Y0" to accompany the "Z0" for tool change; not so successful. I'll have to figure out how to add those two things to that line of code next; it's probably not a bad idea to learn this anyway. At almost 47 years old, that old phrase regarding old dogs and new tricks, is starting to hit home a bit, LoL. Thank you to all that have read this post and refrained from pointing out how dim witted it must surely appear that I am.
                                               Kind regards,
                                                    Mike Ward.
Message 9 of 16
friesendrywall
Look in OnSection, somewhere close to
if (insertToolCall) {
You could post your current .cps file, its not clear what you are starting with.
Message 10 of 16
The attached file is the Meldas.cps post that I currently use, as provided by Autodesk. This is also the file I am attempting to edit. The Mazak MTV-414/22 with Mazatrol M-32 (Mitsubishi Meldas M-335) controller's ISO/EIA programs typically look something like this.
O1000
N1 G40 G17 G94  (Cutter compensation cancel, Set work plane, Feed in IPM) .........In Mazatrol we run feed as IPR instead of IPM, even on the mill, and wish we could in ISO/EIA)
N2 G20 T1  (Inch units, Orient spindle)............I know, I know,....we do not NEED to write either of these codes as the control is set for inch input, Tool pre-load)
N3 G00 G91 G30 Z0 Y0 X0 (Rapid traverse, Incremental positioning, ATC zero return ALL linear axes)
N4 M01 (optional stop)
N5 M06 (Tool change)
N6 T2 (Pre-load next tool in arm)
N7 G90 G54 (Absolute positioning, Set work piece coordinate)
N8 X10.5625 Y4.3125 S2150 M03) (Positioning of X & Y, Set spindle speed, Spindle on CW)
N9 G43 H01 Z1.0 (H-type tool length, Tool length #1, Position 1" above work piece)
N10 Z0.1 M08 (Position to R-plane, Flood coolant on) ..........Turn coolant on at this point to avoid coolant coming on at top of Z travel for obvious reasons.
N11 G81 R.1 Z-.0625 F2.5 (Spot drill 1/16" deep, at 2" IPM, with a retreat plane of .100")
N12 G80 G40 M09 (Canned cycle cancel, Cutter comp cancel, coolant off)
N13 M05 (Spindle stop)
N14 G00 G91 G30 Z0 Y0 X0 M19 (See above explanation)
N15 M01 (Optional stop)
N16 M06 (Tool change)
N17 T3 (Pre-load next tool)
N18 G90 G54  (See above)
N19 X4.0 Y2.0 S2500 M03 (Yep, see above)
V
N2178 G00 Z1.0 M09 (Rapid traverse, Z axis 1" above work piece, Coolant off)
N2179 M05 (Spindle off)
N2180 G91 G28 Z0 Y0 M19 (Incremental positioning, Machine zero point return reference, Z axis to Machinetool zero, Y axis to machinetool zero, orient spindle)
N2181 M30 (End program & Reset)
Message 11 of 16
friesendrywall
For this
N4 T1
N6 M06
You would need something like
    writeBlock("T" + toolFormat.format(tool.number));
    writeBlock(gAbsIncModal.format(91),gAbsIncModal.format(30),zOutput.format(0),zOutput.format(0),yOutput.format(0),xOutput.format(0),mFormat.format(19));
    writeBlock(mFormat.format(6));
Message 12 of 16
friesendrywall
Now your G90 and G91 use I don't understand, that may need further help in the post.
Message 13 of 16
The only time I use the G91 is where the machinetool requires it for tool changes and end of program, to place the headstock away from the operator and the workpiece as close to the operator; other than that I have no use for it
Message 14 of 16
Ok, that got a large part of my needs met. How would I go about moving the "coolant on" function to the first line after the G43 (tool length offset) line of the program? How about moving the spindle speed and spindle on function to the end of the first line of X-axis and Y-axis positioning?
                                        Mike
The attached file is the post as I've altered it thus far.
Message 15 of 16
friesendrywall
Just be sure that the program is re setting G90/G91.
That one is a bit harder, as you would have to move that code into OnSection.  Why can't it just be at the end, just prior to movement?
Message 16 of 16
Honestly, it can, I just wanted to be posting as "polite" of code possible; remember we're a Mazak shop and thus, a bit "spoiled." The idea of placing the "coolant" on function after the initial Z-axis positioning was an effort to not have the coolant on with the Z-axis at it's upper limit. When my guys are doing their "run off" of the first in a given operation, they are allowed to have the doors open (with rapid override as low as possible, and a Z-axis positive offset above any cutting position, of course) to better view what's actually taking place. With the infrequent use of EIA/ISO code around here (they Mazatrol everything they possibly can), it's easy to forget that "Coolant OFF" button on the operators panel; resulting in a face full of coolant as well as all over the floor before you can get to the "Coolant OFF" button for some relief.
 Yes, I know how petty and silly this must sound but, I'd be a little pissed at the guy that handed me code that coated me with coolant while trying to set the job up. "Just always remember to make SURE the "Coolant OFF" lamp is lit before smashing that Cycle Start button"........yeah, I've said it plenty of times having felt no better about the situation; regardless of who's truly "at fault."
Sorry for rambling, and I do TRULY appreciate your attempts at helping my "Java Script illiterate ass" as much as you have thus far.
                                             Kind regards
                                                Mike Ward
