Message 1 of 11
When I post process Multiple paths with the same tool everything works fine. When I post process with tool changes, the first path is 16" higher than the rest of the paths. Actually the first path is normal, then the remaining paths after the first tool change is 16" lower than Z0. I tried using a file that I had used before and it did the same thing. I had a friend test his also and had the same results now. This has just happened in the last couple of days. Attaching pictures the first picture show posting the paths together, then the other 2 pictures are posting them separately by tool.
