Post Processing failure
keywestboats
keywestboats
Greetings,
  I created a simple model, generated cam files , and made my first chips.
Partial success!  I called it a win. I figured a few tweaks and no problem.
Now, the simplest surface 2mm tool path will not process.  Nothing I try will process.
Here is my log file. Can someone decipher this?
Such early success, then stuck for days....  Thanks
Information: Configuration: Mach3Mill
Information: Vendor: Artsoft
Information: Posting intermediate data to 'C:\Users\13059\AppData\Local\Fusion 360 CAM\nc\1010.tap'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Wednesday, April 29, 2020 12:03:41 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5655.0
Configuration path: C:\Users\13059\AppData\Local\Autodesk\webdeploy\production\4e0aaa34365a586c512577121d8984845c4c12c3\Applications\CAM360\Data\Posts\mach3mill.cps
Include paths: C:\Users\13059\AppData\Local\Autodesk\webdeploy\production\4e0aaa34365a586c512577121d8984845c4c12c3\Applications\CAM360\Data\Posts
Configuration modification date: Wednesday, April 15, 2020 2:57:49 AM
Output path: C:\Users\13059\AppData\Local\Fusion 360 CAM\nc\1010.tap
Checksum of intermediate NC data: 8a0c24d917623255b7907544defa72cc
Checksum of configuration: b54456e3e3c5645c02fcba3cf1dba6ec
Vendor url: http://www.machsupport.com
Legal: Copyright (C) 2012-2019 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.8156
Error: Unsupported 'air' coolant.
Error in operation: 'Face2'
Failed while processing onSection() for record 325.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, April 29, 2020 12:03:41 AM
Post processing failed.
Alex
Arun.rs
Hi @keywestboats
Thanks for posting.
You can modify your post processor to support Air  coolant commands like this:
1. Search ' var coolants '
2. Add on/off codes for Air coolant like this
{id: COOLANT_AIR,on: 56, off:57},
I have added M56  and M57 as air coolant, you can add as per the configuration.
For detail info about the post editing please refer the  FAQ link
Regards
Arun.RS
Technical Consultant - Post Processor
keywestboats
Thanks, I stared at it long enough, I cant believe it was that simple. I just changed the setting in tool library. Your answer is more important for me to understand though.  Thanks so much.
Arun.rs
Hi @keywestboats
You're welcome and I'm glad I could help.
Regards
Arun.RS
