I am working on learning threading. So far it's been a failure. Most likely it's something I'm doing but I've run up against a wall and don't know what the problem is so I can't fix it. I've created three different tools and modified my model several times trying to get it to work. No luck. Any help is appreciated. I am using Mach3 Turn along with the most recent postprocessor.
Here is a copy of the log file. It means nothing to me. I also attached my Fusion file.
Invalidated: Design changed: Z axis (Rotary axis)
Invalidated: Design changed: X axis
Invalidated: Design changed: Model
Invalidated: Invalidation due to different value for parameter 'job_rotaryAxis' with level 10.
Invalidation due to different value for parameter 'wcs_orientation_axisX' with level 10.
Invalidation due to different value for parameter 'jobSafeZ_offset' with level 10.
Invalidation due to different value for parameter 'job_model' with level 10.
Invalidation due to different value for parameter 'chuckFront_offset' with level 10.
Invalidated: invalidateByLevel
Invalidated: Invalidation due to different value for parameter 'wcs_origin_turning' with level 10.
Invalidation due to different value for parameter 'job_stockLengthOffset' with level 10.
Invalidated: Invalidation due to different value for parameter 'job_stockDiameter' with level 10.
Invalidation due to different value for parameter 'job_stockInfoDiameter' with level 10.
