post processeur fanuc oi md
lors de la creation d'un fichier , le code EOB (;) n'est pas present a la fin de chaque ligne
comment y remedier
boopathi.sivakumar
@Anonymous
it needs some post edit.
Before editing the post processor file copy the file and do the change as below
Open the post processor file in notepad or any editor
and search for this line function writeBlock()
then you will get to see something like this as below
function writeBlock() {
  var text = formatWords(arguments);
  if (!text) {
    return;
  if (properties.showSequenceNumbers) {
    if (optionalSection) {
      if (text) {
        writeWords("/", "N" + sequenceNumber, text);
    } else {
      writeWords2("N" + sequenceNumber, arguments);
    sequenceNumber += properties.sequenceNumberIncrement;
  } else {
      writeWords2("/", arguments);
    } else {
      writeWords(arguments);
and  add the , ";" in the mentioned line below
  if (!text) {
    return;
      if (text) {
    } else {
      writeWords2("N" + sequenceNumber, arguments ,";" );
  } else {
    } else {
Then save the post now try to post process it will work
Boopathi Sivakumar
Senior Technology Consultant
merci pour la reponse
je ne sais pas comment éditer mon post-pro ni ou il se trouve
désolé pour mon ignorance
boopathi.sivakumar
While post processing in the window you will see this
Click Open config
this will open the file in default editor then use saveas option to copy the file in the same folder (Don't forgot to put .cps at the end of the file name "Example. Fanuc Modified.cps")
and you can search for the line which i had mentioned earlier and do the modifications, save the file now come back to the post process menu you will get to see the new post file.
Boopathi Sivakumar
merci pour ces lumieres ,
c'est rèsolu tout marche !!!
ahmet_mrl_46
Hello, I need a Fanuc oi-md post.
Would you share your post with me?
Can you mail to aziz46mrl@gmail.com.
Any way to create EOB property, because if i turn off "use sequence numbers" it will cease to output ";" at the end of the block.
(properties.showEOBcharacter) {
 So that when post processing there's an option to turn off sequence number and turn on or off ";" or EOB.
