Post process output folder not opening
jm.maskinteknik
jm.maskinteknik
In the past when I posted a setup Fusion would open the output folder then I could name the program and put in  a sub folder
Now when I hit post it just goes straight to my  editor, names the program 1001.nc and drops it in the output folder.
I  always have changed the output folder to one on my desktop.
KrupalVala
HI @jm.maskinteknik ,
We will soon introduce a file name field that will allow you to overwrite the output file name while retaining the correct name inside the file.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
ltomuta
Edit your post, tell it to allow alphanumeric program names and, if your machine does not like them, hardcode a numeric ID to put in the header.
Find
programNameIsInteger = true;
change this to
programNameIsInteger = false;
Find
if (programName) {
    var programId;
    try {
      programId = getAsInt(programName);
    } catch (e) {
        error(localize("Program name must be a number."));
        return;
and replace with
  if (programName) {
    var programId;
    try {
    } catch (e) {
        if(programNameIsInteger) {
                return;
        // keep the machine happy with a number
        programId=10110;
