Post needed for Siemens 840d Mill Turn
The machine is a 2008 Gildemeister CTX620 lathe. The current stock post has many errors and was wondering if anyone would be able to help me get a functioning post working just to get by.
If you need anymore info let me know.
Arun.rs
Hi @Anonymous
Thanks for posting your concern via Forum.
Did you try with the generic Siemens 840d Mill Turn post which is available in the library?
https://cam.autodesk.com/hsmposts?p=siemens_mill-turn
For detail info about the post editing please refer the  FAQ link
Alternatively, you can contact one of our CAM partners via the Service Marketplace who can provide a post for your specific machine.
Regards
Arun.RS
Technical Consultant - Post Processor
rhdfmail
Do you want to post with "gildemeister-structure"?
I tried to figure out a solution for that about a year ago. There is a post somewhere on the forums where someone had a loose idea how to post in that structure without having to do a lot of cut/copy paste afterwards
I would just like the correct feed rates for c axis movements. The radial movements are in G94 which is making the C axis movements take forever. Is there an easy way to edit the template post so it will give me the correct feedrates?
@Arun.rs
@rhdfmail
