Post For New Lathe Question
utekcnc
utekcnc
We are getting a new Hyundai 2100 SY lathe in the shop.   I would like to use Fusion exclusively to program this machine.  What post do I need?  I see there is a Doosan Mill Turn post which would be similar.  This has a Fanuc control.   Is there a stock post  that will work?  If not how do I find one that will work?
LibertyMachine
Chances are that the Doosan post will be "close". I can't stress this part enough: Find a reseller that will modify the post to be exactly what you need it to be. You can find a list HERE.
FWIW, I've used SilverHawk Solutions a few times and they've always treated me right and done a bang up job.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
utekcnc
Thanks,  I'll check into that.   Yes, I want a post that I don't have to change a ton of code in.
sunderlandjoe
I have used Hyundai and Doosan both extensively. They are nearly identical. I'm actually fairly certain they use the same castings. The only difference between the Doosan Puma 400L, and the Hyundai L400 I used is the M-Codes and where the buttons are on the control. (Read: I used the same Fanuc post for both of them)
utekcnc
Were you programming them with Fusion?
