post errors
post errors
post errors
I haven't used fusion for ages and i guess they've changed the CAM stuff quite a bit so might need some help getting back to it.
First problem is Home X not defined (yes the **** it is) how can i get past this error and on to the next one
thanks.
seth.madore
A little bit more info is going to be needed.
Where are you seeing these errors, machine or posting?
What is the post processor? If it's a modified post, please share that here.
Can you share a file that demonstrates this issue?
Seth Madore
Thanks Seth,
I'm seeing  the  errors once i try to post.  Sometimes it will give me the error as I export, or just give me a warning icon next to the file -- regardless, no code is produced that i can actually see. I had a programmer help me with the (attached) post years ago and it has worked fine for years.  It's not perfect but it's never NOT allowed me to actually generate code before.   My fagor 8035 was built before Fusion was a thing so i'm sure this is my main issue but hoping to get back to where i was pre 2020.  Known issues are Circular Interpolation which doesn't work well with G51 E.01 This is look ahead code that smooths out the machine movements.  Sadly, I have to strip that out and replace it with G5 or G7 to get around this error.  The machine runs a bit janky but it will at least cut.  Pretty sure the old fagors are limited to G91 (incremental mode) and that his is the real issue but I've had G90 in my code without issue so it's hard for non programmer like me to really tell.
Thanks again for having a look.
