Possible Surface Inspect bug
Mattxer
Mattxer
I noticed after running a surface inspect that the top seemed to have calculated based on my stock body instead of the selected point. I find it odd because the rest are perfect. The right pic shows that i have the correct surface selected but the left shows it hitting where the stock was.
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
Richard.stubley
Hi @Mattxer,
Could you share this project with myself please. Also could you take a screenshot fo the Right click > Show Results dialog.
Hopefully we can work it out. Also do you have the Feature Flag "Inspect Surface CAD Projection" on? If so, can you turn this off and try re-importing the results. There is a known issue with this and have hopefully got a fix so would like to test your part with the fix.
Richard Stubley
Product Manager - Fusion Mechanical Design
Mattxer
Turning off CAD Projection and re-importing did work. I sent you a pm with the f3d file and screenshot you requested. It's interesting its just the top three and not the rest.
Matt
Matt Smith
Richard.stubley
Cheers Matt,
Thank you for your support on this.
Richard Stubley
